Argh! Ordered a OCZ GameXStream 700w but no molex connectors?!
27 Nov 2007
Ive just bought a OCZ GameXStream 700w from OC but now released after its been shipped that it doesnt have molex connectors...
Is this true? If it is can you buy some sort of adapter which will covert them to molex connectors? Its just that all my fans are molex connectors and wont work if the PSU doesnt have any molex connectors!! :confused:
Cheers!
Toilet-Duck
Theres a review on here which says it comes with 6.
http://www.extremeoverclocking.com/reviews/cases/OCZ_GameXStream_700W_2.html
Technical specifications:
150 x 140 x 86mm
ATX12V v2.2 and EPS12V
OCZ ConnectAll™ universal connectors:
1 x 20+4Pin ATX
1 x 4-pin/8-pin CPU (supports double CPUs/supplies stable voltage)
2 x PCI-E
6 x 4-pin peripheral
2 x 4-pin floppy
6 x S-ATA
High efficiency
80% @ 115V (Typical load)
83% @ 230V (Typical load)
Overvoltage/Overcurrent/Short-Circuit protection
Active PFC
MTBF:100,000 hours
100~240Vac 10-5A 50/60Hz
Edit: Modular means you can unplug a string of connectors. All the plugs are hard wired into the PSU.
I have this PSU, there are 6 molex connectors and what you read was no modular yeah? That just means they are all hardwired and not removable lines, say if you didnt need a line of SATA power connectors you cant remove them from the power supply :)
Where as some you can, the reason for this is its just easier to keep your case tidy. Its a nice PSU by the way, some say they can be noisy but mine is whisper quiet, maybe even quieter, i have never actually heard it, and runs very cool too!
EDIT: read the link, your getting molex and modular mixed up ;)
