Argh, Rainbow 6 Single player demo freezing
20 Jun 2005
London..
Anyone had this problem before?
It has happend twice now, both times at the initial cut scene or whatever its called(when you are in the helicopter). All my other games and demos are perfectly fine, so what could be causing this?After i reboot the 360 i can play fine. Has this happend to anyone else before?
BTW, i got this 360 on Saturday.
Thanks
Well the brick is sitting on my desk a bit behind the 360, not sure. Where else could i place it to give it more ventilation?
I had this with GOW, changed my 360 and everything is good. I went through 4 copies of GOW all the same. It got progressively worse until it got to the point that it would freeze before the game even started. Or I got dirty disc errors.
It wouldn't do it on any other game.
Swapped 360's now no probs.
Could be. If it was just the demo I wouldn't change my 360. Maybe if the full game or another game does it then get it swapped.
The SP demo is known to play up abit (lockups and the like).
The full game locks up on me now and then but it only happens online on laggy servers.
