Bought a couple of blue CCs, installed 'em, and it looks like there's a disco going on in my PC. Is there anything I can easily do to mute the light a bit? I was thinking of wrapping some paper round them but we don't want no fires
vertica said:colour them in with a felt tip pen?
skippi90 said:Turn one off?
window tint you case window
kerrgreg said:7v mod the molex connector for them, or put them on a fan controller?
EvilOne said:They will fade over time, just leave them turned on 24/7 for a few months
Oxy said:why didf u buy led fans for a pc in your bedroom lol?
I don't leave the PC on over night anyway, so light isn't really a problem, it's just annoying when I'm sat at my desk. Just wanted a nice subtle glow, and instead I get the blackpool illuminations
Bubo said:If the tube is not that hot, wrap insulation tape around the tube at intervals. Adjust the gaps between the tape to control the amont of light.
i have mine on a zalman fanmate
using a molex to three pin - it goes into the FC and i control the light
i have two 4" white cathodes on the dimmest setting for some cool, subtle lighting
Out of interest which make are they?
I have used in the past and still have them in the box, some akasa 12" blue cold cathodes. Werent over bright, but trick is to hide the cathodes out of direct sight.
If that doesnt work, then maybe try finding some see through black tape, which may or may not dim the "blackpool illuminations"![]()
Not exactly blue which also annoyed me a bit!
