Argh Why?!?!
How can 10 caps treat over 400 gal? The concentration would be all over the place.
Anyway, why do I even care, they're ********.
If they make the fuel more potent then they might work, right up until you destroy your fuel injectors. They could also be illegal. I wouldn't like to see what they do to your CAT either.
DONT SWEAR
Dangerous
NightShadow said:
lol! somthing tells me these are about as effective as the resistor "chip" that gives you an extra 10BHP.
Scuse me but resistor mods actually work. They alter the feedback coming from one of the engine's sensors, going into the ecu, telling it to put in a teeny little bit more fuel. I know they work, because i've made my own using two pieces of wire and an actual resistor. Power gains/compatibility will obviously depend from car to car.
But those MPG caps.. well they'll work in the same way the fuel system hose magnets work, IE not a jot..lol :D
It depends on the car, anything post stone age will sense the extra fuel via the lambda probe, and self re-map to compensate after a few days.
Don't tell me, you got +20bhp?
