ARGON EXTREME INTEL CORE I3 530 2.93GHZ @ 4.40GHZ OVERCLOCKED BUNDLE
11 Dec 2005
Cheshire
Argon Extreme Intel Core i3 530 2.93GHz @ 4.40GHz Overclocked Bundle @ £299.99 inc VAT
Designed by experts the "Argon Extreme Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Extreme Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Featuring USB3.0 support straight out of the box
Bundle Specification
- CPU: Intel Core i3 530 2.93GHz @ 4.40GHz
- Motherboard: Asus P7H55-M/USB3 Intel H55 (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Akasa Venom CPU Cooler (H70 upgrade available)
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £299.99 inc VAT.
ORDER NOW
Is there any hope of getting more than 4 GB of RAM to run at this sort of speed.
Wouldn't be too comfortable buying with 4GB, have you guys tried to see if you can get a high stable overclock with more than 4GB at all?
I would also like to know this.
it becomes very difficult to be honest.
generally speaking the chips dont like pushing this hard with full banks of memory.
