Ark Dedicated server help please!
6 Oct 2004
Birmingham
I'm trying to get an Epic enabled dedicated server set up for Ark so my mates can play with the version that's currently free, but having issues getting it running :(
I'm using ASM, and I've run the same server before, but for steam only.
I've tried enabling the -crossplay and -epiconly flags in the server args, but when I do, it doesn't work:
With just -crossplay, I get an error on launch:
"FOnlineSubsystemEOS: EOS_Initialize() threw an exception and was caught in __except block.
FOnlineSubsystemEOS: failed to initialize the EOS SDK with result code (2147483647)."
The server launches and I can connect directly by IP, but it doesn't show in the server browser and I can't use a password.
If I also use the -epiconly flag, the server won't even launch, the cmd window pops up for a fraction of a second and then closes again straight away.
I can launch and connect via the server browser using the exact same config on my PC, so it's not a config issue.
Anyone encountered this same issue before and solved it?
Wahey, finally managed to fix this...
Thanks to the totally useful (not) error message, I finally managed to figure out I needed to install the Visual C++ 2015 redistributable - it's now working :)
