There has only been 1 official patch so far the big patch is still in QA.
This tells you how playable the game has been since launch daythe PC community reaction towards this game is shocking
The game was only pulled due to Steams refund policy as WB were losing a lot of money as each refund means they still have to pay Valve their 30% or whatever their cut % isYes the game was pulled due people complaining for no reason.![]()
so it was losing money due to refunds as the game was not quite 100% for some configs. WB overeacted the game is very playable & has been since day one!This tells you how playable the game has been since launch day![]()
But if I like it then everyone else must be wrong and complaining unfairly, amirite.
2 Missing FX were fixed in the 1st patch. All the other issues are very simple ini tweaks which is why someone created a tool on Steam for thisYup, everything about the game was unbelievably polished. I don't really know why people were complaining so much. Ummm... Maybe because of the 30fps lock, missing effects, low-res texture bugs, shoddy ram management and biblical lag spikes? Just a gut feeling, though.
2 Missing FX were fixed in the 1st patch. All the other issues are very simple ini tweaks which is why someone created a tool on Steam for this![]()
I am going to have agree to disagree here the game works properly for many people. I have put in over 100 hours now the only crashes ingame I had were due to a VRam memory leak in Panessa studios when accessing the ingame map (which is overly complex anyway). I have played for 6-8 hours in 1 sitting with no crashes whatsover in several lengthy sessions.You're completely missing the point. Why should WE be responsibe for fixing the game we paid our hard earned money for? Or wait for patches restoring fx that should be there on lauch day?
I fully agree but every PC game seems to be broken at launch in some form for someone due to the millions of hardware configs out there at least it was fixed in a very short space of time.
If the issues were such "simple" .ini tweaks then why didn't the devs get rid of them prior to releasing the bloody game?
Millions of different hardware configs no-one can possibly launch a PC game today which will work on all configs without months of expensive QA which would make PC games economically unfeasable.
Stop defending WB, it was a huge ****-up on their side. Doesn't the fact that some random bloke had to sacrifice his precious time to make a tweak tool and managed to fix some of the issues the devs couldn't fix during the entire development cycle put the company in a bad light?
I am not defending them at all just stating it works for most PC gamers with a few simple ini tweaks.
Besides, the tweak tool in question doesn't make the game perfectly playable. Lag spikes are still there, especially during batmobile sections. 60fps is a pipe dream and it shouldn't be, given how dated the engine is.
60FPS is easy to achieve just disable all Gameworks settings except the Enhanced Rain. Tweak the ini file how hard can that be I get no lag spikes @ 4K which is a very demanding resolution for any modern game especially this one
The fact that it works for you doesn't mean that people have no right to complain. I shouldn't be having any problems with this game with a 970 at 1500mhz and a 4790k but I do. Other games, some of which are bigger and better looking, run practically flawlessly. Something's not quite right here, is it?
I had no problems with my GTX 970 & only 6Gb Ram
EDIT: What's more, even the author of the said tweak tool said it won't make things perfect or work for everyone since the devs made a complete hash out of everything;p
I guess thats why Nvidia sponsored the game & paid a lot of money to give it away with their GPU's !
The game was only pulled due to Steams refund policy as WB were losing a lot of money as each refund means they still have to pay Valve their 30% or whatever their cut % isso it was losing money due to refunds as the game was not quite 100% for some configs. WB overeacted the game is very playable & has been since day one!
WB patched in the missing rain & AO FX the only thing the game really needs is slight tweaking of the ini files to improve how much RAM is allocated to the texture streaming system which is easy to do someone even created a tool to tweak it all here:
http://steamcommunity.com/app/208650/discussions/0/523890046870624615/
Nvidia are guilty of using this game to sell their top end GPU's that seems to be what its designed around but even then you have to disable all Gameworks features except Enhanced Rain to get it to 60FPS. I am talking about 4K as well on a single GTX 980 Ti with a mechanical HDD not even an SSDI guess thats why Nvidia sponsored the game & paid a lot of money to give it away with their GPU's !
If anyone cannot get 60FPS on a GTX 970 @ 1080 then they are doing something wrong that GPU has no problems with this game @ 1080 even the batmobile sections are very smooth. Its all about tuning your HDD or SSD to stream the textures smoothly an issue all UE3 games have this one uses streaming all the time due to how complex/large the ingame environment is.
The no 1 technical issue this game has is the texture streaming which is easily fixed & that causes stuttering if you do not tune the game to your config![]()
And if people can't get satisfactory performance on a 970, they are doing something wrong? Because that's what you make it sound like.
It only takes a couple of simple tweaks, after all;p
