ARMA 2 LAG?, and media lag also
25 Jun 2009
right heres my system,
Dell Inspiron 531
AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ (2 CPUs), ~2.6GHz
[2 of these]DIMM1: Micron 8HTF12864AY-800G1 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
[2 of these]DIMM3: Kingston KPN424-ELG 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
NVIDIA GeForce 9800 GT+ OC+ (1024 MB)
[HDD]SAMSUNG HD321KJ SCSI Disk Device (320 GB, 7200 RPM, SATA-II)
Rights guys major problem, when i watch films, the films lags at different parts of the film, doesnt matter wether its dvd or not, any format = lag, isnt much but it intereferes with the film and annoys me. this happens in any multimedia, music, films and games, i recently bought ArmA 2 and on any gfx detail it lags, the same way the music and films does, i really need help guys, please :D
Welcome to the forums
Can you post a screen images of CPU-Z (all tabs)
What OS are you using?
My guess is that it's the memory which aren't matched.. you have PC2-6400 and PC2-5400. Thuis is fine when running 1:1 but it could be causing latency problems.
Also, since your GFX card is 1GB, the mapping function is taking a nice chunk out of that 2GB.
i would get 4GB of matched PC-6400 regardless if you us a 32 or 64 bit OS.
What OS are you using, and what revision of the audio/chipset and graphics drivers are you using. It sounds like a graphics driver issue. I would download the latest suitable Nvidia one and see if it removes the issue. Uninstall the old one reboot then install the new one reboot.... bliss hopefully :)
right, im sorry to seem dumb :(, but what is the screenshots you wanted? of the cpu-z? i am using Vista Home Premium, anyway i could stop the GFX card taking so much memory or will that always be that way?
Cheers :)
It's unlikely it's a hardware problem.
It's either a driver issue, crappy codec install or bug in the movie player. (WMP)
