arma control schemes
18 Oct 2012
here's a headscratcher for you guys
so despite arma 3's massive list of controls you can never seem to be able to rebind to what you want. the current issue i'm having is no matter what i tell the control menu it insists that changing optics mode is "ctrl t" regardless of the fact literally no actual control is bound to that combo but the control is bound to just "t" (which doesn't work)
so before i'm like "**** it i'm using a macro" anyone care to shed some light as to what the hell is going on here?
In the weapon drop down menu the default bind ctrl+t is stabilize turret. Also if you use Arma3 dashboard there is an option you can tick - Use same unit as last time. This will stop your profile being reverted back to default profile each time you start your game.
