Armed Assault graphics issues
Man of Honour
17 Oct 2002
Hi all,
Just installed my new 8800GTS, went to play AA and.. I've got loads of weird graphical curruption. The sky, for example, flashes yellow.
Any ideas?
o/ Fox,
What card have you changed from? ati -> nvidia?
Have you done a drivercleaner run or reformat?
What Forceware drivers are you using?
Are the card temps ok?
Is AA the first game you've ran with the card or are other applications etc fine?
Can you run a 3dmark test to see if you get any graphical corruption or if it attains an expected score?
8800's are notorius for graphical problems tbh, driver support is horrible. AA is no exception, a lot of people with 8800's are having problems, should be resolved soon enough with new drivers from nvidia due out in a few weeks.
JC said:
o/ Fox,
X850 XT > GeForce 8800GTS
Done driverclean.
97.somethingorother.
Yup.
Eve runs fine.
Will try that :)
Hey man, I had a similar problem with my GTX, except for the flashes I believe were white... if it is the same problem. Sounds like it though.
It was all fixed by me installing the latest drivers at the time, though I havn't updated to the most recent ones yet. I mean the ones released around Christmas.
Hope that helps.
.one. said:
runs like **** :D
Heh, mine runs fine. Only got it on 1280x1024 and full everything, but still... runs pretty well, unless I look across a whole load of transparencies.
