If I remember correctly, if you go up to the vehicle, a little box appears in the bottom right hand corner. You select each option by scrolling you mouse wheel and then click the wheel to select that option......if that makes any sense.
Well the obvious solution is to go into your options and configure the controls so you can see exactly what's available and assign them to keys you're comfortable with and then you'll know EVERY control
Walk up to appropriate door/hatch on the vehicle and use the scroll wheel to select the relevant option in the bottom right then click the middle mouse button to select it.
