Armorsuit PC-P50R Panel Clips
27 Jul 2014
Cheshire UK
Hi, does anyone here know where i might be able to get some of the "older style" front panel clips for an Armorsuit PC-P50R. I bought some from OCUK (part No. PT-JT01) but there a newer design and are not compatible with my case. I need the ones that screw in to the panel. Since buying the wrong ones, i have googled & googled but am having no luck whatsoever.
UPDATE:
After emailing Frozen CPU i got some of the older style ones, postage was well reasonable and the guy i spoke to was really helpful.
