26 Sep 2009 at 21:52 #1 Vakas Vakas Associate Joined 8 Apr 2009 Posts 1,880 Location Manchester Does the Thernaltake Armour Plus front fan have a dust filter with it? if so do you have to remove the hard drive cage to access it?
26 Sep 2009 at 21:58 #2 Scooby_WR1 Scooby_WR1 Associate Joined 20 May 2007 Posts 1,042 Location Stoke-on-Trent Front looks like my armor so the filters are built into the bay covers.
26 Sep 2009 at 22:08 #3 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester The filters on on the covers but I cant seem to open the bottm 4 where the hard drive cage is and the front fan that comes pre installed.
26 Sep 2009 at 23:16 #4 Scooby_WR1 Scooby_WR1 Associate Joined 20 May 2007 Posts 1,042 Location Stoke-on-Trent Not sure then because mine just pull out and then the fan is screwed onto the hard drive cage the armour+ might be different. EDIT: Like this. Last edited: 26 Sep 2009
27 Sep 2009 at 02:10 #5 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester The drive bays at the bottom dnt hav a gap on the right side to put ur finger in to pull them off it is closed off unlike the top bays will pull off
27 Sep 2009 at 14:32 #6 Scooby_WR1 Scooby_WR1 Associate Joined 20 May 2007 Posts 1,042 Location Stoke-on-Trent Just noticed that the armor+ has a removable hard drive bay, i should imagine that you would need to remove that to gain access to the fan.
27 Sep 2009 at 16:54 #7 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Yeah the fan is connected to the back of the hard drive cage and once you remove thae that you can remove the front drive bay panels. Seems a bit time consuming just to clean the filters...
27 Sep 2009 at 18:42 #8 rexehuk rexehuk Soldato Joined 13 Jun 2009 Posts 4,273 Location My own head Hoover it... I used to hoover from the front of my armour and it used to suck all the dust out.
27 Sep 2009 at 23:58 #9 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Will try that
