It gets worse. Installed Armoury Crate with new Crosshair hero viii. it seemed like a good idea at the time. The software recognised my ROG peripherals, (flare keyboard, qi mat etc) and requested an update and reboot. On restart is all worked wonderfully. however a few days later it asked to be updated again and is stuck in the endless 'installing but not installing loop'
no problem thought I. I'll go back to using armoury II in order to access my flare keyboard settings.
unbeknownst to me these updates from aura had re-written my device firmware without informing me.
now armoury II tells me "this item can only be used on the armoury crate software"
and armoury crate tells me I need to install an update which it fails to install.
my very expensive rog peripherals are now useless.
