Arr someone help?
9 Nov 2013
We'll I'm in process of building my first computer but I'm stuck.
I've come to a cable that says it's an EPS. Does this go into the EPU slot on motherboard?
If you look on asus m5a97 evo r2.0 motherboard it's the blue socket with 8 pins called epu, at side it says EATX12v, the power supply is an antech hcg520 comes with a connection called eps12v
Ahh up by the CPU socket left hand side?
Yes connect the two to make a single 8 pin plug and plug it in,its for the CPU power
