Array failed dropped to initramfs on boot
4 Dec 2002
Bourne, Lincs
So one of the arrays on my NAS has died, squealing drive death noise etc etc, anyway server rebooted and now Ubuntu will not boot as there are not enough drives to bring up the array, which is annoying as I have lost a load of stuff but nothing I cannot get again.
So I do not have my live-cd to hand nor any blank CD's to burn a new one, but on boot it drops me out to (initramfs)
I know if I can etc my fstab file I can remove the lines that auto mount the arrays and get booted into Ubuntu but I can not find the command or how to do it, I did try sudo vi /etc/fstab but tells me sudo: not found
Anything else I can try before I get some blank CD's?
Cheers
Kimbie
Tried the USB stick route but the mobo I have doesn't seem to want to boot from it.
Will have a look at the single user mode option to see if its there and give it a try
Thanks
Have you tried just vi'ing the file without the sudo. Given how early it's bombing out in the boot process your console session is probably running as root.
