Array related question
4 Mar 2007
United Kingdom
Okay, so I'm figuring out the differences between Java and C# at the moment as I usually mess around with Processing.org's - processing language.
I've seen in for example C#
Code:
float className[,] objectName = new Classname[ firstPart , secondPart ];
and was wondering what is Java's equivalent. Is this the same as
Code:
float className[][] objectName = new ClassName[firstPast][secondPart];
or is the C# still a single dimensional array with two components in it?
You're correct that the functionality is in essence the same, however they are different. More info on exactly what the differences are is here.
The 'int[,] x' syntax is the textbook method of declaring a multi-dimensional array, however you can also use 'int[][] x;' in C#, it's called a 'Jagged array' or 'Array of Arrays' - a full list of array types is here
