** ARRIVING SOON - PLASTIDIP **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Over the past few weeks I have been working to get Plastidip available at OcUK.
Plastidip is a great product as it allows you to spray your hardware and change colours of things like cases, graphics card coolers, backplates, fans etc on a semi permanent basis.
if you change your mind down the line, it peels straight off.
best of all it is long lasting, waterproof, cold proof and has multiple uses. loads of people use this stuff on their cars too!
for a case modder, this really is a great product.
Plasti Dip is an air dried flexible liquid matt coating for use on virtually anything!
Plasti Dip resists alkaline, acids, salts, moisture, abrasion, and most chemicals, and is an insulating dielectric coating.It will not crack, chip or peel, and will remain flexible even under severe conditions (-34ºc to +93ºc).
Plastidip is ideal for computer modding as it allows colour customisation without the worry of permanent change. Users can modify the appearence of their cases and if they change their mind, they can simply peel the plastidip off!
Plastidip is ideal for use on plastics such as keyboards, mice, speakers, headsets, fans etc.
used correctly, you can put Plastidip on just about anything as a method for changing aesthetics for long term or temporary use.
It doesnt have to stop there, plastidip can be used on pretty much any suface and is really popular for other applications such as automotive modifications and other electronics projects.
Plastidip protects coated items against moisture, acids, abrasion, corrosion, and skidding/slipping, and provides a comfortable, controlled grip. Plasti Dip remains flexible and stretchy over time, and will not crack or become brittle in extreme weather conditions. It has been tested and proven in extreme temperatures.
Wood: Seals and protects from weathering, and prevents splitting.
Metal: Reduces vibration, deadens sound, and prevents corrosion.
Glass: Shatter proofs glass objects (available in clear).
Also... Plastics, Rubber, Fibreglass and concrete surfaces!
NOTE: Surfaces which are non-absorbent such as metals should be primed using specialist Plastidip Primers.
here is a demo of how it works
Check out our range here
Retail: $8.99
UK Price: £14.99
Not saying you're to blame but why such a high price?
Looks good though :)
I've used it on some cosplay for a christmas party and this stuff is great, but the UK price is too damn high.
Really good to see OCUK getting this stuff though, it will be my place to buy it in future, and hopefully it means it will become more widely known in the UK and maybe the price will start to go down.
lol at price. needs better deals for that to work.
its 3 times as dear as paint.
because its not the same as paint. :)
the price is competitive in the UK market and we are one of the cheapest suppliers for single cans when you account for free forum member postage.
Retail: $8.99
UK Price: £14.99
where is it available for $9?
most places list it for £15-£18
the Plastidip UK website has all the cost prices on so there really isnt much to hide.
you can get a can for £7.04.
but then you have to pay VAT.
and buy 499 other cans to get that price :)
In the video you posted it states that the retails price is $8.99:
cool. well that's the states.
as I have already mentioned, the pricing in the UK is available for everyone to see on the plastidip UK website.
its simply not available for that price in our region. the price we have it listed for is pretty much middle of the market in UK pricing.
obviously, most stockists dont offer free shipping either which makes it more towards £20 a can.
Great product,
Do better on that price. :)
you can always buy direct from Plastidip UK and save 25p if our pricing is not to your liking.
Product Total: £11.00
P & P: £4.00
Vat: £3.00
Total: £18.00
even without free shipping for forum members, a can from us WITH shipping is £18.25
P & P: £4.00
Vat: £3.00
Total: £18.00
I bow to your clarification with the numbers.
I was being cheeky and meant no offence. ( sorry in any case)
The reality is that the product is marked up as you state in the UK.
The plastidip is a premium niche product fellow readers.
Yup, exactly like that. Peels off too once your done with it. The finish resembles a textured powdercoat. There are examples around of whole systems covered in the stuff.
Loads of vids on youtube, they even coat cars in the stuff, complete colour changes.
Great for people who want to change colours of a case/component/anything.
