I just cannot decide which monitor to buy for my new setup!!! I've scoured people's opinions and through the sticky's etc - but just cannot decide!!!
I'm after a single 20" widescreen monitor (may buy another, depending on funds
) - will be used for playing games and all other media. Not specifically for movie's etc.
No set budget in mind - but would like good bang-for-buck value of up to £300 ish (may go higher for something if it's highly recommended)... Would like DVI connection though.
Have looked at Iiyama 22'' PLE2200WS, Viewsonic VX2025wm, NEC MultiSync® LCD20WGX2, Dell Ultrasharp 2007WFP and so on...
So folks - what's your recommendation?
) - will be used for playing games and all other media. Not specifically for movie's etc.No set budget in mind - but would like good bang-for-buck value of up to £300 ish (may go higher for something if it's highly recommended)... Would like DVI connection though.
