Hi,
I have noticed that my PC has been getting very hot, especially the front of the case.
Temps have always been a bit higher than normal and after having a good look I have put it down to my X800XT PE gfx card, as it blows the hot exhaust air directly on to my HDDs and the metal frame at the front of the case.
I have just ordered a Artic Cooler 5 for the card, I know that the Zalman is the better option, in most cases, but the big plus with the Artic cooler is that the exhasted air will be dispelled out of the back of the case, instead of heating up the front and cooking me slowly in the process.
I have never done any mods to gfx cards before, so have a couple of questions:-
1) How easy will it be to remove the existing cooler on the card ?
2) Will it we worth removing the pre-applied thermal conduction material and applying some AS5 instead for the GPU core and memory chips ?
3) Any other useful tips will be welcome.
Cheers
Diddy
Cheers
Diddy
