Bought one of these last week, I had the original Silentium T1 which died when I pushed the 350w PSU too far, so this was a natural replacement.
Bah humbug to OcUK for sticking it on offer less than a week after I bought it!!!
I'm in the process of writing a small review for it (I was going to wait until I got my DS3, but now it's on offer I feel my hand has been forced) I'll post it up in a little while, photos will follow probably tonight (including one of the PSU).
There are some new issues, which will affect some people, but some other things have been sorted out.
Oh and in the meantime, the DS3 should be fine, but there is a small issue with the Arctic freezer 7 pro because you have to mount it backwards to compliment the air flow of the case, this means it's tricky to get the CPU fan plugged in on some mobos because the wire isn't quite long enough.
However, this can be easily sorted by feeding the wire through under the heatsink, not ideal, but no harm done.
If you have any questions about the case, chuck them my way and I'll answer as best as I can.
Edit: review is here - http://forums.overclockers.co.uk/showthread.php?p=8452419
