hi all,
i fitted this cooler and im getting temperatures of 50c seti load and 43 idle with 35/36c case temps (hot room) is this way too high for this cooler as I've read its meant to be very good. A lot better than what I get temperature wise.
people who run this did you wipe the paste that came on the bottom of the hs off before fitting it and apply good stuff? if so does this make a lot of difference?
thanks for any help.
