Hi
I cannot for the life of me install this heatsink & fan. Im having to use excessive force to get it anywhere near clipping on; if i push any harder its going to go straight through the motherboard.
Im trying to install it on a Skt939 MSI K8N Neo4 motherboard with a AMD X2 4200; could it be incompatible with my setup?
This is the 2nd Artic Freezer ive had, as the first one snapped when I tried to lock the clip and ive not had any luck with this one.
Mark
Mark
(basically got arsey with it and forced it on)
However the locking arms were short stubby things so when you think about it; boils down to simple logic - a longer lock arm requires less force as its futher from point on tension.
Iirc the ACF pro 64 ones are quite long so id have been **** scared to use a lot of force incase of cpu crushing...
