- 6 Sep 2016
What is the fan screw spacing for Artic? I'll be cutting holes in case I've found templates for radiator/fans but doesn't say what artic use for their fan spacing
What about putting some paper/card over the radiator and punch holes where the screws go?No I mean radiator sizing, if I get 280 where would I need to drill all screw holes relative to the other fan template. Compared to just fitting one fan, the 4 screw holes and large hold can go anywhere.
Fan sizes are pretty standard on hole spacing. I think 120mm 140mm is the diagonal:
The weird thing about some Arctic fans is the plastic "supports" near the screw holes - depending if you are using screws or bolts with large head like mushroom bolts they might not fit.
www.mnpctech.com
Every single AIO I've had has had the fans flush against each other with no gab between them.Are you talking about Arctic AIOs rather than their fans? There shouldn't be a gap as is the case as for nearly all radiators so fans sit flush next to each other but I dont have one to confirm.
This is pretty much always correct these days (for like 10 years) and it is 15mm between fan holes centre to centre.Every single AIO I've had has had the fans flush against each other with no gab between them.
