Artic Silver question
thats if you bought Arctic epoxy.
Glue/thermal compound
mix 50/50 with arctic silver 5
Arctic Silver Thermal Epoxy (7g) (OA-001-AC)
Thermal compound, no mix required
Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC)
i think you are confusing arctic silver, with the completely different arctic epoxy adhesive (which is supplied in 2 syringes like araldite)
the normal stuff never sets
the arctic silver is for cpus
the epoxy is not for cpus but is for permanently attaching heatsinks to chipsets, ram chips etc-just bought some as it happens
