So I initially bought a 7990 from a competitor as part of a hardware bundle which comprised of a i5-3570K clocked to 4.5Ghz with a Corsair H100i cooler a Asus P8Z77-V an Akasa Venom 1kW modular PSU and a Samsung 500GB 840 Pro SSD (I re-used my existing 4x 4GB 1866Mhz Corsair Vengeance RAM).
Initially I had overclock stability issues and I was unhappy with the temps on the i5 so I swapped the CPU back to my prior 2700k which was nice and stable at 4.6Ghz and at decent temps considered the low end W/C'd setup.
However, I then started noticing Artifacts from time to time, mostly when playing BF3 but sometimes even whilst at desktop and doing various things. BF3 results in wireframe / screen tearing oddness (still happens with vsync enabled which also then makes the game feel jittery) where as in Windows I get odd blocks that show up - see this screen shot which was a VNC window running: http://www.axerite.com/jing/2013-03-14_0128.png
I tried uninstalling and re-installing both the latest normal release drivers as well as beta, installed/uninstalled the CAP profiles and even tried downclocking the GFX and CPU but the problem persisted.
Last but not least I dug deep and bought a second Ares II, from OcUK this time and I fitted this yesterday but STILL the problem persists.
What are we thinking OcUK?
1.)I don't see how it can be the RAM or CPU as they are from before, worked fine for 1yr+ and I've tried downclocking anyway
2.) It can't be GFX card, I've already swapped it
3.) I can't see it being a corruption issue, the OS install is fresh and everything bar this display issue works fine
4.) Temps throughout the system are absolutely fine
Could the PSU cause this? I read reviews and it was pretty well rated...?
Thanks!
Thanks!
