As my teacher used to say to me everyday "BE QUIET"
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys!
We have the latest CPU coolers from BeQuiet ready for pre-order now. We will be the first UK stockist with stock arriving the start of next week.
BeQuiet Shadow Rock Pro CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £36.98 inc VAT
The decoupled 120mm Shadow Wings PWM fan (SR1) / 135 mm Shadow Wings PWM fan (TopFlow) guarantees the best relationship between cooling effect and audible noise. The wave-shaped contours of cooling fins minimize noise and optimize air flow.
Four heatpipes transport heat via the shortest path to the optimal point within the cooling fins. The Single-Fin layout is a compact means to attain the best heat dissipation from every individual cooling fin whereas the TopFlow cooler layout provides optimal cooling for the CPU as well as for nearby system components. Completely nickel plated heat sink. The stable backplate ensures vibration-secure attachment, even when
- Number of heatpipes: 4
- Dimensions (incl. fan): 122 x 158 x 95 mm
- 1 x Shadow Wind PWM Fan inculded
- Weight (incl. fan): 740 gram
- Fan Dimensions: 120 x 120 x 75mm
- Fan Speed: 1700 RPM
- Noise Levels: 7.8 - 21.4dBA
- Air Flow: 57.2 CFM
- 4 pin PWM connection
- Black Plate Mounting Included
- 3 Year Warranty
Only £36.98 inc VAT.
ORDER NOW
