- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
I thought it would be rude not to offer a deal on XFX for it.
So here you go.
XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply @ £59.99 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: up to 1
- Fixed Peripheral: up to 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 8
Was £69.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £74.99 inc VAT
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed SATA: up to 11
Was £92.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
So here you go.
Was £69.99 Inc. VAT
ORDER NOW
- Fixed FDD: 1
Was £92.99 Inc. VAT
ORDER NOW
