ASA 5500 DNS Inspection
Caporegime
19 Apr 2008
Essex
Having a bit of an issue related to DNS requests being dropped, the people that built the DNS server have given it a clean bill of health so I thought I would check the firewalls.
Currently there is this configuration in place;
Code:
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  no dns-guard
  no protocol-enforcement
  no nat-rewrite
policy-map global_policy
class inspection_default
and if I show the service policy it's indicated that it has dropped over 10k packets
Code:
show service-policy inspect dns
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: dns preset_dns_map, packet 2785300613, lock fail 0, drop 10769, reset-drop 0
        message-length maximum client auto, drop 0
        message-length maximum 512, drop 0
The only thing that seems out of place is that there's two lines for the max message length, could this be causing a conflict? As all the configuration examples I have seen just show 512 which is the default.
*edit* Just realised having two lines is fine and is the default config for newer ASAs for DNSSec.
Any help would be appreciated.
What DNS servers do you run? Does it only happen to certain top level domains like .co.uk?
No real pattern, sometimes it'll work and others it won't.
Also spotted this;
Code:
show asp drop frame inspect-dns-invalid-domain-label
  DNS Inspect invalid domain label (inspect-dns-invalid-domain-label)       4842
Last clearing: Never
pri/act/Venom# show asp drop frame inspect-dns-invalid-pak
  DNS Inspect invalid packet (inspect-dns-invalid-pak)                       126
pri/act/Venom# show asp drop frame inspect-dns-pak-too-long
  DNS Inspect packet too long (inspect-dns-pak-too-long)                    8996
So the ASA is dropping packets, might up the max size to 4096 to see if that alleviates the issue.
Just noticed you have the client auto parameter already, but you also have the 512 parameter (which presumably overrides the auto). I would drop the 512 parameter (leaving the client auto)?
Seeing it on Cisco configuration examples though, in all fairness 10k packets dropped out of 2 billion isn't a great deal.
