ASDL2+ wireless router recommendations
11 Sep 2008
Northern Ireland
So I have the stock BeBox router (TG585v7) and it is absolutly horrible. It always shuts down at least once a day and it doesn't properly forward ports sometimes.
On the wireless whenever I go to play games I get a 4 second lag spike every minute or so, and of course whenever I use an ethernet cable its perfectly fine.
If only I could use an ethernet all the time but unfortunately I can't, so does anyone have any good suggestions? Thanks
I use my BEBox in bridge mode (modem only) to a better router. It's quite easy to set up, as you do it using the BE installation CD. I like the look of the ASUS Black Diamond if you were going to go this route.
