- 8 Jan 2011
Hi folks. I have this cooler on my i5 2500K 3.3, P8P67 rig. When I have tried to overclock (4.3GHZ +) and run prime95, the temps go above 75C. It idles at around 30C.
At the moment there is only 1x 120mm fan pushing air through the rad from the case out through the back. Would cooling be improved by reversing the direction (cool air in from outside) and adding another fan for push/pull?
Plenty of airflow through the case (2x 120mm intake at front, 1x 120mm intake at side and 240mm exhaust at the top.
