Asetek 690LS Cooler / Antec 1200
30 May 2016
Hiya folks!
I'm looking to upgrade to a overclocked system with an Asetek 690LS AIO CPU cooler. I've been told the 360mm radiator will go fine in the front of my case, but I'm thinking - is that with the drive cages or not? I've got a couple of drives in their already!
Any thoughts?
Because Simon B from OC recommended it!
I gave a budget of circa 150 quid and a window - any size. Want would you recommend then? I reckon it's something to do with the fact that the Cooler Master Trooper SE case looks not dissimilar to my Antec 1200!
wow thats an expensive bundle!
is there anything your looking for specifically in a case? silence , size, style, colour?
At the moment I have a 5.25 slot cover giving me several USB 3/2 ports - a couple of ports isn't enough. There was a time when new cases had loads of slots available at the front, but nowadays it seems that new cases are clean and free of - anything!
USB2 ports arent needed if theres usb3 ports on there since older devices can be used on them, saves space, cables and cost. some like the Dynamic/p600s/678c have USB C ports on them as well.
Most users will plug at the back of the mother boards I/O as depending on your mobo chipset, these are native and dont run off 3rd party controllers.
corsair 678c and Phanteks pro M also allow 5.3" drive to be used as well
