Asetek AM4 bracket to fit Corsair Hydro series?
Asetek are the OEM for.... pretty much every AIO in existance (Kraken, Corsair, Thermaltake, etc) any of them with the GPU block, tubes and a radiator with the pump in the block - Asetek Patented design.
As such, if it's the right shape (circle or square) the bracket will fit... 99% certain. The blue part you can see is to help hold the ring onto the block so it's not a tedious annoyance to fit :)
Ordered as I recall exact same thing. Trying to slap up a budget ryzen 7 for video editing and h115i seemed like an idea :D
Cheers!
