ASIO drivers for onboard sound?
4 Jan 2004
¯\_(ツ)_/¯
I've got a gigabyte p965 ds3, is there any way to give it ASIO functionality? I'm using the digital output for what it's worth...
Sorry to bump - but does this really work as well as a dedicated low latency soundcard?
i.e. will my Asus P5W onboard sound perform as well as my E-MU 0404 pci card?
The latency was a little lower (only 1 or 2ms) on my E-mu 1212m than it is compared to onboard.
I can't tell the difference myself, but some people might...
The only annoying thing is ASIO4all keeps forgetting my buffer settings, perhaps a new version may have fixed this.
I've intalled v2 just now and been testing out with onboard Realtek, and noticed a lot of pops and bumps indicating latency issues. I've set it to 512 samples (12ms in FL Studio) which should be ok.
I guess I should stick to the 0404. I would like the PCI slot back though for a proper wireless card, hence looking at this.
Is the E-mu 0202 USB any good?
Yep I ran outta PCI slots too. :(
I'm not sure about the E-mu 0202 USB, but I know the E-mu 0404 USB gets very good reviews...
Another option would be to use a USB wireless adaptor and stick the 0404 PCI in the PCI slot.
Yeah much cheaper to do that,and nowt wrong with the current 0404.
I guess this should go in networking, but seeing as you have good taste in kit - any recommendations on a new wireless USB stick + ADSL router combo?
Sorry I didn't see this thread until now, I used to use a D-link USB wifi adaptor a while back, seemed to work ok, and seemed to get a similar connection speed to my PCI wifi card. :)
I'm sure that if you make a thread in networking you'll get recommendations for specific models... I'm more into my sound that networking. ;)
