usually you can access it with the music software you use ?
i use reason3/cakewalk project5 for example its found in audio settings
other wise it should be in the audio console ... might have to scroll allong ???
i cant remeber were my audigy 2 one was exacly
as i have an x-fi xtreme music now
if you cant find it , have you tryed to reinstall the drivers ... there is a stand alone driver set avalable now .... drivers and audio console only .. includes asio control panel
