Well, the position of the northbridge is between my gpu and large processor heatsink, Xigmatek Achilles.. I've read some article that told us to stick a fan on it, but I think it won't fit..Point a fan at it maybe?
I'm using HW monitor..Hmmm how do you know your northbridge temp.?
I'm currently using Coolermaster Storm Scout,everything runs cool, except for the northbrige and my 4870..ahh ok, what case do you have mate.?
I've tried searching for this product here, but I can't find it yet..You could use something like a Antec spot cool or a Zalman fan bracket to mount a fan. Failing that would a 40mm fan fit on it?
Just had a look at a piccy of your board and it does look a little tight on space between the GFX card slot and cpu socket. I would be tempted to change the cooler to one of the Thermalright ones.
