If anyone with Vista 32 or 64 could try the follwing I would appreciate it.
If you run the "Add New Hardware" wizard and select the option that reads something like "Show me all devices, I will select from a list" and then select the Network Adapter class. Are there any Dlink products listed ?
I am specifically looking for the DGE-530T which is a PCI gigabit card.
I'm sure the beta release supported Dlink products but the release versions seem to not do.
The Dlink web site is no help - They have some beta drivers for some wireless products.
Thanks
Thanks
