- 13 Jul 2005
- Brisbane
Hi Chaps,
bit of a newb-a-tron to ASP and have the below sub to reset a user's A.D password.
It currently works, but i want it to throw up an error box if the username entered is not recognised by the A.D, and then return to the start of the sub.
Thanks in advance,
Tucks
Code:
'Reset Password
Sub Btn3_OnClick
Dim User
Dim UserName
UserName = inputbox("Enter the Username you want to change the password for :","UserName","")
if len(trim(UserName)) = 0 then
MsgBox "Please specify a username.",,"SMS 2003 Remote Control"
exit sub
end if
NewPassword = inputbox("Enter the password you want it changed to :","password","")
Set User = GetObject("WinNT://" & UserDomain & "/" & UserName & ",user")
Call User.SetPassword(NewPassword)
User.SetInfo
End Sub
Thanks in advance,
Tucks
