I'm new to asp.net and have a half decent understanding of sql. However its been years since i used it (sql).
i want to get started with programming using sql and asp so of course i need the software to get started. What software should i use to get started? Because i want to teach myself. Obtaining the documentation for my learning is no problem but i just need to know what software i should use.
Any advice is appreciated!
p.s i heard sql enterprise or something? and enable iis?
hold on and I'll find you the link
