asp contact us form
2 Oct 2004
N.W London
Hi there,
This is the asp contact form source code I need to setup a contact form
Trouble is when I click on the submit button I get a page full of code instead of the error.html page appearing advising user to go back and complete required fields on my form
Where am I going wrong?
Thanks
Dim error
error = 0
For Each f In Request.Form
If Request.Form(f) = "" Then
error = 1
End If
Next
If error=1 Then
response.redirect "error.html"
Else
Dim f, emsg, mail_to, r, o, c, other
mail_to = "[email protected]"
fline = "_______________________________________________________________________"& vbNewLine
hline = vbNewLine & "_____________________________________"& vbNewLine
emsg = ""
If mid(f,1,1)<>"S" = True Then 'do not save if input name starts with S
emsg = emsg & f & " = " & Trim(Request.Form(f)) & hline
End If
Next
Set objNewMail = Server.CreateObject("CDONTS.NewMail")
objNewMail.From = Request("Email Address")
objNewMail.Subject = "Message from contact page (version: 1.0)"
objNewMail.To = mail_to
objNewMail.Body = emsg & fline
objNewMail.Send
Set objNewMail = Nothing
response.redirect "thankyou.html"
End if
Page full of code indicates your host doesn't support ASP or you've named your file wrong,
Is the file named say contact.asp, not contact.htm?
This is the .html form called quotes.html
The above is the .asp code called "contactusprocess.asp"
<form action="contactusprocess.asp" method="post" enctype="multipart/form-data" name="Quotes_Form" id="Quotes_Form">
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>Pickup Date
<input name="Date" type="text" id="Date" onblur="MM_validateForm('Date','','R','time','','R','Name2','','R','Phone','','RisNum','email','','RisEmail','Pickup','','R','Dropoff','','R','Pax','','R','vehicle ','','R');return document.MM_returnValue" size="12" maxlength="12" />
Pickup Time
<input name="time" type="text" id="time" size="12" maxlength="12" />
</p>
<p>Name:
<input name="Name" type="text" id="Name" size="20" maxlength="20" />
Mobile Number:
<input name="Phone" type="text" id="Phone" size="15" maxlength="15" />
</p>
<p>Email Address:
<input name="email" type="text" id="email" size="40" maxlength="60" />
</p>
<p>Pickup From (Inc Postcode):
<input name="Pickup" type="text" id="Pickup" size="35" maxlength="40" />
</p>
<p>Drop Off (Inc Postcode):
<input name="Dropoff" type="text" id="Dropoff" size="35" maxlength="40" />
</p>
<p>Flight Number:
<input name="Flight_Number" type="text" id="Flight_Number" size="10" maxlength="10" />
Total No. Of Passengers:
<input name="Pax" type="text" id="Pax" size="5" maxlength="20" />
</p>
<p>
No. Checked In Luggages:
<input name="luggages" type="text" id="luggages" size="8" maxlength="50" />
Vehicle Type:
<input name="vehicle " type="text" id="vehicle " size="8" maxlength="15" />
</p>
<p>Comments:
<input name="Comments" type="text" id="Comments" value="Any additional requests to be entered here" size="55" />
</p>
<p align="center">
<input type="submit" name="Submit" id="Submit" value="Request Quote" />
</p>
</form>
to answer your question the file is definately named - contactusprocess.asp
my host definately supports .asp as I barely know the basics
the .asp code above is borrowed from the internet :)
This is the most likely culprit then.
Does the 'page of code' exactly match your .asp file? If so then the code is not being processed correctly by your server and you'll most likely need to have a chat with your hosting co.
It could be that they support ASP, but have not enabled it on your account. Or perhaps they thought you meant ASP.Net, which is completely different.
yes you guys were correct thanks for that
the host is clicking a few switches for me to allow asp
thanks for that
so now if i use the above code does that mean everything will be work? is that .asp code above correct?
thanks for all your help
