ASP do until loop
21 Feb 2004
HI, in the following code i want to acheive to have multiple variables with corrisponding numbers. for example
Code:
dim connections
connections = 0
Do Until connections = 10
dim blah+(connections)
connections = (connections + 1)
Loop
so i will have 10 variables named blah1-10. I just cant quite figure out how to add on the number.
I only want this for serverside use, not response.write.
Thank you
in ASP the names of variables cannot be evaluated as code, they must be plain text, so you'd have to define dim a1, a2 rather than say dim 'a' & i + 1.
The best way to do what you're after would be have an array and fill it in your loop
Code:
dim arrArray(10), iConnections
iConnections = 0
do while iConnections <= 10
  arrArray(i) = szWhatever
  iConnections = iConnections + 1
loop
oh right thanks.
What i really want to do is i have a record set which brings back multiple rows and from those rows it brings back i want to insert each record into another table. How is this possible? ive been looking at some ado methods but struggling on how to use them.
i am using MYsql as dbobject.
Thank you
