ASP error - help!
10 Nov 2004
Kent, England
Hi there,
I am trying to read records from a database on an asp page. My current code is:
set conn=Server.CreateObject("ADODB.Connection")
conn.Provider="Microsoft.Jet.OLEDB.4.0"
conn.Open(Server.Mappath("fpdb/WebSite.mdb"))
set rs = Server.CreateObject("ADODB.recordset")
rs.Open "Select faqid from tblFAQ", conn
do until rs.EOF
for each x in rs.Fields
Response.Write(rs.faqid)
Response.Write(" = ")
Response.Write(x.value & "<br />")
next
Response.Write("<br />")
rs.MoveNext
loop
rs.close
conn.close
-- Getting.
Microsoft VBScript runtime error '800a01b6'
Object doesn't support this property or method: 'faqid'
/bradleygallery/index.asp, line 19
Where have I gone wrong?
To find wherre the bug is, you could try and replace your conn.open line with something in this format:
conn.Open "c:/webdata/northwind.mdb"
If that works, you'll know it's sometihng wrong with your map function.
