ASP Help - Linking form to Access
10 May 2004
East Yorkshire, UK
Hi
I get a server 500 error on this code, does anyone know why?
PHP:
'Dimension variables
Dim adoCon          'Holds the Database Connection Object
Dim rsAddComments   'Holds the recordset for the new record to be added
Dim strSQL          'Holds the SQL query to query the database
Set adoCon = Server.CreateObject("ADODB.Connection")
adoCon.Open "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & Server.MapPath("database.mdb")
adoCon.Open "DSN=database"
Set rsAddComments = Server.CreateObject("ADODB.Recordset")
strSQL = "SELECT order.FN, order.SN, order.AL1, order.AL2, order.AL3, order.PC, order.HN, order.MN, order.I1, order.I2, order.I3, order.I4, order.I5 FROM order;"
rsAddComments.CursorType = 2
rsAddComments.LockType = 3
rsAddComments.Open strSQL, adoCon
rsAddComments.AddNew
rsAddComments.Fields("FN") = Request.Form("FN")
rsAddComments.Fields("SN") = Request.Form("SN")
rsAddComments.Fields("AL1") = Request.Form("AL1")
rsAddComments.Fields("AL2") = Request.Form("AL2")
rsAddComments.Fields("AL3") = Request.Form("AL3")
rsAddComments.Fields("PC") = Request.Form("PC")
rsAddComments.Fields("HN") = Request.Form("HN")
rsAddComments.Fields("MN") = Request.Form("MN")
rsAddComments.Fields("I1") = Request.Form("I1")
rsAddComments.Fields("I2") = Request.Form("I2")
rsAddComments.Fields("I3") = Request.Form("I3")
rsAddComments.Fields("I4") = Request.Form("I4")
rsAddComments.Fields("I5") = Request.Form("I5")
rsAddComments.Update
rsAddComments.Close
Set rsAddComments = Nothing
Set adoCon = Nothing
Response.Redirect "ordercomplete.html"
Many Thanks
I can't see anything specifically wrong in the code, so it could be that the database is not in that location, the SQL has an incorrect field name or even ADO isn't installed.
If you change the IIS to show detailed error messages your browser will tell you the exact error and line number when you run it.
