Asp.Net Calendar Control - NON popup.
~J~
~J~
20 Oct 2003
London
Does anyone know of a free ASP.Net Calendar, ideally similar to this little beauty:
http://www.telerik.com/demos/aspnet/Calendar/Examples/DatePicker/CustomPopup/DefaultVB.aspx
(Try clicking on the month, as it's really impressive).
Need a calendar control PDQ that allows the users to select a month/year and should ideally be a non-popup window.
The Yahoo.UI is a nice calendar but that requires a popup!
Would really appreciate any feedback on this.
Yeah it's a wonderful calendar, but don't you find it kinda slows things down?
But thanks, will definately give it another look.
If by any chance you stumble across a tutorial or some code from creating a popup calendar without using AJAX, i'll appreciate it if you let me know.
I searched and tried several but they never seemed to work
This is the one I was using but my client wanted it non-pop-up. But I've used it for numerous projects and it's worked really well.
http://developer.yahoo.com/yui/calendar/
Very nice!! Thanks.
