- 31 Dec 2003
- Barrow-In-Furness
I'm using a Calendar control to allow the user to select a date, based on their selection a set of results is fetched. Every time they select a new date it will cause a GridView to DataBind and get the new results.
For some reason though, if I try select todays date it does not postback and cause the Calendar1_SelectionChanged event to fire, it just does nothing.
It works for every other day except todays date. Todays date is automatically highlighted (not selected), but I can't figure out the problem.
There are two bits of code which relate to the Calendar..
Anyone got any ideas?
Code:
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Calendar1.SelectedDate = Date.Today
End Sub
Protected Sub Calendar1_SelectionChanged(ByVal sender As Object, ByVal e As System.EventArgs) Handles Calendar1.SelectionChanged
LoggedHoursGridView.DataBind()
End Sub
