ASP.NET parse string and replace with usercontrol
Izi
Izi
9 Dec 2007
I in my article body content I have files embded as so:
<# FileID='4494' Link='' LinkText='' Resize='185' CssClass='' #>
At run time I need to replace these with the actual file its self (be it a image or link to a file)
How would you go about getting the properties of the string in to a class?
if using regex, what expression would you use? Really need to learn more about regex...
so far:string expression = @"\w*(&lt;%)(.)(%&gt)*";
Got it working using:
string expression = @"\w*(&lt;%)(.*.)(%&gt)*";
However, would still be interested to know other peoples approach on this?
in case anyone needs this in the future this did the trick:
public static string ParseBody(string body)
string pattern = @"\[#\s+((FileID=(?<FileID>[\w ]*)|Link=(?<Link>[\w ]*)|LinkText=(?<LinkText>[\w ]*)|Resize=(?<Resize>[\w ]*)|CssClass=(?<CssClass>[\w ]*))\s*)*#\]";
MatchCollection matches = Regex.Matches(body, pattern);
foreach (Match m in matches)
EmbedFileHelperClass item = new EmbedFileHelperClass();
item.FileID = Convert.ToInt32(m.Groups["FileID"].Value);
item.Link = m.Groups["Link"].Value;
item.LinkText = m.Groups["LinkText"].Value;
item.Resize = Convert.ToInt32(m.Groups["Resize"].Value);
item.CssClass = m.Groups["CssClass"].Value;
string emdedHtml = processEmbedFile(FileManager.GetFileByID(item.FileID), item);
body = body.Replace(m.Value, emdedHtml);
return body;
