ASP.net PopUp Calendar
Capodecina
Permabanned
31 Dec 2003
Barrow-In-Furness
Does anyone know of any good tutorials?
I need to create a typcial popup calendar, with the selected value going into a TextBox within a DetailsView.
Can't seem to find any tutorials that actually explain anything, or even work for that matter.
Just to point out, don't forget that the textbox is in a DetailsView.
Therefore, it won't be able to find the textbox on the page. So you need to use DetailsView1.FindControl() in your code to find the textbox in the DetailsView.
