Ok I have an asp (vbscript) page that it used to show server status.
it works like this:
It all works fine but because several servers are pinged it takes a while (10-20 seconds) to load the page.
Anyone know how I can add a progress/loading bar either for each <img> tag while it pings the server or just the whole page if I can do one for each ping/img? Would It be client or server side?
edit: My aim is to have the page load instantly even if the pings aren't complete. The loading/progress bar should be displayed then replaced by the green/red icons when pinging is done.
Thanks for any help
it works like this:
Code:
<img src="<%=checkip("[I]some ip[/I]")%>">
function CheckIP(sIP)
[I]some code that pings the IP[/I]
if ping is successful then
return url to green icon
if unsuccessful then
return url to red icon
end if
end function
Thanks for any help
