Aspect scaling
Caporegime
13 May 2003
Warwickshire
I can't find much useful information on this - can someone explain whether I'm correct in saying that it allows lower-than-native resolutions to still fill the whole screen on a TFT, like CRTs can do?
If this is the case can someone tell me if the new Dell 24" TFTs support this as I want a 24" monitor but won't be able to get a GTX in the same month.
Many thanks.
The default on pretty much all screens is for non-native resolutions to fill the screen. What the expensive monitors like the 2407WFP can also do is show the resolution 1:1, or scale it while maintaining the aspect ratio (which would give you side borders on 4:3 resolutions but at least it wouldn't be horizontally streteched). Most people don't want resolutions like 1600*1200 just stretched to fill the whole screen on a 1920*1200 screen because the aspect ratio is wrong and everything looks horizontally stretched (ie too flat).
Of course if you're using a 16:10 mode like say 1280*800, 1440*900 or 1680*1050 on the 2407, you get the option to either have it stretched to fill the screen (which is what I would choose), or have it displayed 1:1 (which would give you borders all round and a small picture).
Bullseye. Thanks buddy.
Clarkey - what do you mean by your comment.
