I agree 100% - this is a GREAT board - especially for the price and the options it gives youNicos Rex said:This board can be regarded as a useful option as a stepping stone to the full-blown DDR2/PCIe system.
I have one myself and it will eventually be relegated to my son's system.
I am delighted with the board whilst understanding its limitations - the chipset is significantly slower than any of the current NVIDIA or Intel ones.
It really depends on what you have now. I went to this with an e4300 from an Athlon XP2600+ which I had never managed to get much above stock. The difference in things like encoding is outstanding and the overall "feel" of my system is a lot brisker.
As has been said, there is an FSB limit of around 300, but this is still a "modest" 50% overclock which is not to be sneezed at by any means.
To sum up this apparently endless ramble - as long as you don't expect miracles the board offers a flexible upgrade path at a very reasonable cost - particularly if you will be able to reuse it in a second rig for another family member.
ron3003 said:Dont let the 4x pci-e slot put you off too much. Physically its a 16x slot just electrically limited to 4x
Nicos Rex said:It really depends on what you have now. I went to this with an e4300 from an Athlon XP2600+ which I had never managed to get much above stock. The difference in things like encoding is outstanding and the overall "feel" of my system is a lot brisker.
Bernie_Li said:I currently have an AMD XP 1800+ with 512MB RAM and I find my system slows down when running a few things like internet, watching Freeview via my TV card and listening to MP3s etc. I am thinking of getting the Asrock 4Core Dual as I don't play games and can just re-use my AGP card and get 2GB of DDR2 memory with an E2160/E4300/E4400.
Does your Core 2 Duo system or anyone else's system stand up to "normal" uses like above? i.e multitasking on PCs in the past has been nigh on impossible IMO.
I do encoding (AVI to DVD format) from time to time and using ConvertXtoDVD takes about 2+ hours on my current system. Does anyone have any figures for their improvement in encoding with the C2D chips?
although I just picked up an e2160, i think that the e4400 is your best bet. As mentioned above, the FSB is limited to around 300Mhz (although i've seen it higher with volt mods) so if your overclocking, you'll want that 10x multiplier so you can squeeze out those extra Mhz.Bernie_Li said:I currently have an AMD XP 1800+ with 512MB RAM and I find my system slows down when running a few things like internet, watching Freeview via my TV card and listening to MP3s etc. I am thinking of getting the Asrock 4Core Dual as I don't play games and can just re-use my AGP card and get 2GB of DDR2 memory with an E2160/E4300/E4400.
